The one and only Prius Plug-in FAQ!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by lensovet, Nov 24, 2012.
  1. ikefor
    ikefor Member
    106
    35
    Lagos
    2015 Prius Plug-in
    Yes indeed, this is a nice find......i am a new (used) owner of a 2015 PIP and was quite confused as to what trim it was until i saw the link. From the link, it appears that the PIP comes in the two trims, the Plug-in Hybrid and Plug-in Hybrid Adv. I have the Plug-in Hybrid as I don't have leather seats or JBL but the sound from the speakers are really really nice. I have the 2010 Prius III with the JBL speakers and i can tell that this comes to par if not better.
  2. Civiceg94
    Civiceg94 Member
    58
    44
    Nyc
    I have a 2012 plug in prius as well but everyone mention only two models. I dont either one. Mine is leather non powered seats with non jbl navigation system what model is mine ?
  3. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,317
    Central Virginia
    Go to the Toyota Owners site and register your VIN. You can also see what dealer service was performed.
  4. bisco
    48,945
    base , w/aftermarket leather.
    Yea Right, markabele and Prodigyplace like this.
  5. Suds
    Suds Member
    31
    30
    Wichita
    You can purchase the Toyota remote starter, part number PT398-47091 (available in the PriusChat Shop, your dealer, or any number of sites), which will allow you to preheat the car. Note that the charger must be disconnected from the vehicle before it will start.
    My dealer says this remote start PT398-47091 "replacement number PT398-47110" will not work on my 2012 Prius plugin. Has anyone tried it?
  6. bisco
    48,945
    if you have to go out to unplug, can't you just start the car at the same time?
    jerrymildred and Prodigyplace like this.
  7. Prodigyplace
    11,696
    11,317
    Central Virginia
    I think the Remote Starter lets you keep the doors locked without needing to resort to the skeleton key.
  8. Suds
    Suds Member
    31
    30
    Wichita
    true but the idea was to use it away from the house
  9. Suds
    Suds Member
    31
    30
    Wichita
    What's irritating is the Toyota parts web sites that list it as an option, but that is false information according to the dealer's when they check the VIN, maybe my Plug-in Advanced has something that breaks the deal.
  10. redhotz
    redhotz Member
    49
    29
    Cleveland, Oh
    I had a local car stereo/alarm shop install this.
    . Cost $300 installed. Work great. I don't always plug in.
    Directed Electronics 4X10 Digital Remote Start System with 3 Lock.
  11. Suds
    Suds Member
    31
    30
    Wichita
    Thanks You can use factory remote right but short range?
  12. redhotz
    redhotz Member
    49
    29
    Cleveland, Oh
    Yes, factory remote, just press lock button 3 times. The range, of course, is the range of the factory remote. I preset the heated seats and defrost. Only downfall is, if your plugged in ( I have a PIP), it won't let you remote start.
    #352 redhotz, Jan 11, 2019
  13. Karl Goh
    Karl Goh Junior Member
    31
    New Zealand
    i-Tech
    wonder if anyone noticing any battery degradation as of yet? seems like a problem that plagues Nissan Leafs
  14. QuantumFireball
    QuantumFireball Active Member
    416
    267
    Ireland
    My estimated range is about 0.2 miles lower than last winter, I'm not sure if other things have affected this though - I've moved to tyres with higher rolling resistance among other things.
    vvillovv and jerrymildred like this.
  15. bisco
    48,945
    many have observed 10-20% over the first few years, then stabilizing. yours probably won't change much now
    leaf was a whole nuther beast, but degradation was worse in hot climes
    Dreamsite likes this.
  16. markabele
    5,084
    1,782
    Nebraska
    Yes, everyone is going to see some degradation on these batteries even if one claims they have seen none (hint: their driving habits and/or weather has changed without them realizing it). Toyota did a decent job protecting these batteries but the C rates on them is just too substantial to not have some degradation. When you can run a battery full to depleted in about 7 minutes, that is going to create some problems. The vast majority of people don't use them like that, but even charging on a basic L2 has a C rate of about 1 or less.
    vvillovv and bisco like this.
  17. vvillovv
    vvillovv Senior Member
    3,529
    1,241
    NY
    I've been guessing at around 10 to 15 miles. Looks like I'm close if your 7 minute figure is dead on.
    My maphs no so good though lol it's way hard !!!!
    good seeing you here again.
    markabele likes this.
  18. Dreamsite
    Dreamsite New Member
    Toronto
    2020 Prius Prime
    Sorry newbie ques here...My new house is under construction and is now waiting for the the drywall installation....
    Can someone share me
    1. the cable
    2. breaker required
    3. Outlet/ charger required link
    so that I can do it now..... for changing the Prius/RAV4 Prime... Much appreciated for your help!
    Thinking to get the 2021 RAV4 Prime once released....
  19. john1701a
    john1701a Prius Guru
    12,747
    5,243
    57
    With new construction, your best all-around install is a NEMA 14-50 outlet on a 50-amp breaker using 6-gauge wire.
    #359 john1701a, Dec 2, 2019
  20. drash
    drash Senior Member
    2,450
    1,228
    Upstate NY
    What @john1701a said. The breaker will probably be a dual 50A breaker, one for each 120V leg. I mounted NEMA 14/50 outlet near the garage door so it can be accessed from outside as well as inside the garage. The charge door will be on the rear passenger side for the RAV4 Prime like it is on the PiP and Prime so you can plan on placement. Enjoy!
    iPad ? Pro
    vvillovv, jerrymildred and Dreamsite like this.
